1 - 4 of 4 Posts
· Registered
I'm new to this procharged stuff and I just picked up a new MSD 7535. I was going through the instructions and saw there is a cam sync pick-up. :confused: Do you need to use this function or can I add it later? And do you hook the ignition up to the laptop with the grey cables that have the screw thinggys (sp) in them?:confused: Thanks in advance, Clint
· Registered
Sorry, I missed this one. The cam sync allows you to have individual cylinder timing control. Not hooking it up will not adversely affect the running of the car. If you wish to add it later that wont be a problem.
Yes, the laptop will hook up with the serial DB9 cable.
1 - 4 of 4 Posts
