1 - 6 of 6 Posts
I cut the roll bar out and getting ready to install the 8.50 CM cage. I will not be putting the back seat back in. I was thinking of installing 1 1/4" kickers of the main hoop to the rear lower control arm front mounting point. Do others do this? Will it help stiffen the frame?
Is there any other bars I should put in?
Also what size should the front J bars be? The bars that go through the fire wall to the front frame.
Frame rails min 1.5 forninsidenof cage. That said I'm planning my tube chassis being 1.5 for all the structure.
Blair that's my fat fingers bumbling on a phone keyboard. Was supposed to be 1.5 for everything outside the cage. 1.5 inch for what 25.2 rule book doesnt specify and 1 inch for cross braceing outside as well. That has most of the floor and some braces in 1.5
1 - 6 of 6 Posts
