Seeing its the first dodge you have done theres 1 helpfull thing you might want to know.Mopar converters come in 90 degree and offset bolt patterns.there should be a stamp on the converter saying its a 90 degree,that meaning it can be bolted up in any position,just like a gm or ford.If you are unsure you can measure from center to center of the bolt holes of the converter.If its offset put the dot on the converter as close to the oblong hole in the flexplate.That will be the correct place for all the holes to line up.Its more of a time saver thing,if you dont its not a big deal you will just have to keep starting the bolts and spinning the engine over to find the right spot where all the holes line up.
