1 - 4 of 4 Posts
Bough a 98 vette with 161K miles. Trans shifts extremely hard from 1-2. Tech 2 shows pressure control solenoid. Will it hurt to drive it for a few days till I can get it in to have it repaired?
It will be fine, do yourself a favor and while you have the 1-2 acumulator housing off to replace the epc solenoid replace the plastic 1-2 piston with aluminum.
Unless the trans has been gone through at some point change out the two shift solenoids too. They will be the next to fail.
1 - 4 of 4 Posts
