1 - 4 of 4 Posts
Dr. Greenthumb
I just aquired a 95 GTS from my brother. Im wanting to just set the engine up like a fox body. Without using the elbow on the intake, and the plate on the front for the power steering and all. Im going manual steering, no smog pump, ect. Does anyone know of any issues of doing this ? I know the accassory plugs are different.It has the old school Pro-M kit to repin the harness and put the A9L ECU in it. So I'm thinking of swapping out the harness as well. The engine bays are pretty much the same I believe arent they ? My goal is to do the turbo build I was planning on my fox in the 95. If I did this, I should be able to use a fox turbo kit right ?
Dr. Greenthumb
I figured so. What you been up to man ? Havent talked to you for a while. Im living back down here now.....FINALLY !! lol
Trying to get one car running and wishing the other one was running right.
Hadn't seen you on any of the local boards; welcome back :)
1 - 4 of 4 Posts
