1 - 11 of 11 Posts
We just finished a BBC ,Merlin block,Brodix BB2X fully ported heads,10.3CR mech roller ,Dale Cubic carb,SV intake,it made 895HP at 6900rpm and 742 torque at 5800 rpms,we ran it on Sunoco 93 octane only.Bill C.
Good deal!
Nice job.565 is a nice combo imo.That will be a animal on the street.
Whats that engine for?streetrod /drag /boat?
598 Coming Soon
:-Daw Sounds very similar to my build, Hasn't been fired yet....Will let you guys know hopefully @ the end of October, Good job
Discussion Starter · #10 ·
Thanks for the kind words guys ,Engine is going in a 71 Camaro Pro-Street deal,It is for one of our guys in the shop,it started out as a good parts purchase from Racing Junk,a short block and head package,quite a bit of massagging later,it has Mahle shelf pistons,eagle crank and rods bolt upgrade,std cam barrel and .842 Isky Red Zone EZroll lifters,Comp Cams 7-4 swap,static cr is 10.35,dynamic is 8.11,we were not bash full on cam area and prefer not to broadcast specs at this time The Brodix BB2X were sent to Mikes Racing Heads in Concord N.C. 415cfm ,Dale Cubic did carb ,it has a primary power valve,Comp belt drive and ATI damper were more Racing Junk parts,Moroso vacuum pump 15 in.draw,Jesel rockers ,combo of some used and some new parts.Moroso catalogue pan,7/16-3/8 taper pushrods,Nextek polished 221425 springs,Thanks to all that contributed to this project.Bill C.
1 - 11 of 11 Posts
