I just wanted to see what the consensus is. I am a huge fan of E85 but I wouldn't be able to use it if I was to drive more than a couple hours from my house. Locally, its everywhere but I would like to race at a couple 1/4 mile strips that are about 2-2.5 hrs away. Two other strips that are about 5 hrs away. With that said....
Two identical engines, cars, set up...can I do the same ET with 91 that I could on E85? If not, how much difference? My goal is only sub 6 in the 1/8 consistently and daily driven with around 20mpg.
Car 1969 Chevelle, will be 3400lbs, great working suspension.
Engine 5.3 stock bottom end, with arp rod bolts, ring gap opened up to .028 on the top ring, Cam XER273 224/230 .581/.588 on a 114, stock heads for now with Patriot Gold Dual valve springs to .650, arp head studs, edelbrock throttle body intake with tall edelbrock elbow
Turbo's twin pt62's with stock wiring harness and ECM using hptuners, (air to air cooler and meth injection if I don't use E85) 40mm wastegates
Basically, can this be done without too much headache on the 91 or will E85 give me my only chance? I am wanting to run E85 but several are saying I can accomplish this on 91 and then I could still drive it anywhere. Figured I would ask some opinions.
Fuel System: Currently running A1000 but figured with the E85 I would have to run dual fuel pumps. Not sure if I would need to if I run 91?
