1 - 13 of 13 Posts
Custom Engine Shop
Con, it is alot more money.
to make the power level you are wanting a standard journal bearing 91 will make it without breaking a sweat,
Exactly. On a 2JZ, a FI-91X made 1481rwhp......I don't think 1500 crank HP is a problem....hehe
A 2JZ makes damn near any turbo look good for peak horsepower numbers on a dyno.
Now why doesn't anyone ask the appropriate question of what engine will you be putting this 91mm turbo on? RPM? Trans?
I got $5 that says this guy isn't putting the turbo on a 2JZ.
- Brian
- Brian
Same car with a GT55 made 1398rwhp....same boost pressure. If that puts things into better prespective.
I will agree though, the 2JZ is a nice platform for #'s.
Ball bearings, too me, are overrated.
For one, you are on a 2 step/brake...the slight spool advantage of a BB will NEVER be seen in that situation.
The upfront costs are much higher and the rebuilds are insane.
I would never choose to run a BB turbo, unless someone has some good reason to...
That's excellent power!!
Too bad the powerband is so short on those motors!!
Yes.......its like a light switch. The customer is in Turkey and apparently 2JZ's are the craze over there at this time.
1 - 13 of 13 Posts
