Then get a big block & you can have twice that. If all you want is 2201, stick with your little block. :roll: sheesh, some folks are REALLY hard headed. :roll:
Would the same run true for a 500 cid BBC with a 106mm? Which would work better, pro's and con's? What about IAC do you need it ? Does it help at all? Mark
