1 - 3 of 3 Posts
I have changed from N/A to turbo charged and with the 3.73 rear gears I was thinking of launching in 2nd gear. I have done this in the past to slow down to 11.50's(no cage) but with another 200+ hp I assume the 904 will fold up quickly. Any opinion on what will give up first in the transmission? Thanks
The band, the servo on a 904 is not that large to begin with so leaving in 2nd will accelerate the band wear. The band is a weak point in the transmission to begin with, so i would suggest not trying this honestly. if you wanna slow it down, you'd be better to short shift, lower the stall or change to the higher gear ratio 2.45 instead of 2.74 if that is what you have.
1 - 3 of 3 Posts
