1 - 5 of 5 Posts
So when I put my center together it seems I got pretty lucky that everything was correct because I had no idea there were different pinions. I have a stock 9" center out of an old truck i got then found a street gear and install kit and put it all together and it has held up great.
I am looking to make my rear end stronger for peace of mind and future setups and i need to step the gear down so I am trying to figure out what to look for. Now I know when I gave my drive shaft guy my u joint dimensions he said right there is a weak link and there is a bigger joint I should upgrade to.
Does the big and small pinion have different center sections or just different bearings? My locker is a 31 spine and I am assuming I have the smaller pinion correct?
What pinion spline yoke and pinion support should I buy and when I do will the iron center be the new weak link? How do I identify
If it doesn't have an "N" in the center yes it will be a weak link. When and where is the question. Also depends on what gear ratio your running.
Do you mean a stock support and a Daytona support? If so the inner bearing on the Daytona support is bigger. They fit all the case's. The stock case's have either a 3.062 or 2.891 side carrier bearings.
1350 series joint.
it is not nodular. So if I get the bigger pinion with the correct support it would bolt right in? can I run an alum center on the street? Is the carrier bearing just a matter of what gear ratio you have or is it depending on axle splines?
I guess you could but I wouldn't.
Yes. I've swapped from a stock style 1310 series joint to a 1350 series with no problem.
Not gear ratio, depends on what case you have. If you go with bigger splined axles and a bigger carrier then you will have to go to a 3.25 side carrier bearing case. The 2.891 and 3.062 fit both 28 and 31 spline axles. I don't know if you can go bigger haven't tried.
1 - 5 of 5 Posts
