1 - 20 of 257 Posts
Any links to Forward facing turbo set-ups 87-93 stangs.. Centered and high enough to drain to pan with out an oil pump. Thanks for any pictures.
Thanks.. His motor looks lower anyone know who make that one piece nose?
Discussion Starter #7
Tim86 Is your turbo high enough to gravity drain back to the pan..
Yes
Yes no problem, takes no time between passes to cool it back down. 160 leave the line 190 at the end. No problem
how do you guys cool the engine? where is the radiator?
Discussion Starter #18
I have a 5 gallon water tank we put a little ice in and use it to cool the motor
Your 5 gallons cools the intercooler then motor? I'm looking to run a 7 gallon tank and cool intercooler, trans, and then motor..
What engine temps do you see?
I have 1 for the motor and 1for I/C temp depends on how much ice i put in. I have a friend he runs a 7 gallon it's ok making about 2k hp
Do any of you guys street drive with the smaller radiators?
I'm looking to do a front facing setup and that's all pending on how good I can keep it cool on the street. You know like going to the local car meets and just going on a cruise at night.
1 - 20 of 257 Posts
