21 - 40 of 42 Posts
Discussion Starter #22
I ran the wires down the frame rail here. I
Also ran all new brake lines front and rear.
60855
Discussion Starter #23
I only had the cheap plastic wire loom handy at this point but I ended up buying some of the nice fabric type fire resistant wire loom for the rest of the car.
60856
Discussion Starter #26
Made a switch panel to fit where the radio was. Not super great but gets the job done.
60859
Discussion Starter #31
I made a little plate to mount the relays and power distribution strip. It’s mounted on the trans tunnel right at the firewall under the dash.
60866
Discussion Starter #33
I did a 5 lug swap to make buying wheels easier. I used ranger front hubs and brakes and ranger axles for the rear.
I also swapped an 8.8 in the car and had it re geared with 4.56s.
60870
Discussion Starter #35
Unfortunately my camera on my phone stopped working so I wasn’t able to get pictures of a lot of other things. I’ll probably use my wife’s phone and get some pictures in a few weeks to add.
otherwise, this is how the car sits now. Mostly complete, I just need to do the interior. Right now it is just two kirkey seats but I will be adding carpet and a 6 point cage and an actual rear seat delete of some sort.
60873
Discussion Starter #37
I cut a little piece of the license plate to make room for the battery switch.
60876
21 - 40 of 42 Posts
