1 - 20 of 42 Posts
Since we can post pictures straight to the site now, I figure I’ll post up some progress from my build.
The car is an 86 notchback, original 4 cylinder auto car, I picked up as a roller for $900.
The engine is a 347 I had built years ago but never got around to putting in anything until somewhat recently.
specs are
Stock block, neutral balanced 347
10:2.1 cr
236/243 .603/.588 cam
Afr 185 heads
Funnel web intake
750 quick fuel carb
Picture from when I bought the car
Discussion Starter #2
K member coming out to be replaced with a Team z k member, a arms, and Strange coil overs Also changed over to manual steering.
60826
pulled the dash so that I could re wire the entire car.
I used an EZ Wiring kit and re wired the car with only the essentials. Lights, ignition ,fan and water pump. Heater box was also pulled.
60828
also decided to smooth the engine bay this time since the engine was out. This was my first time smoothing an engine bay and learned that next time I will just buy the smooth panels. Lol.
60833
Discussion Starter #7
boxed the frame rails and shaved the sway bar mount. Not shaved in this picture.
60835
Discussion Starter #15
passenger corner looks weird in the picture for some reason but looks good in person.
60845
Discussion Starter #16
Mounting up coil overs. Using the stock 86 spindles, I had to grind them down a bit to make them fit.
60846
Discussion Starter #17
Got the engine set in there using solid motor mounts. I also switched to manual brakes. Ranger master cylinder with a willwood prop valve.
Discussion Starter #19
Wiring harness from EZ Wiring. 12 circuit piece but I ended up only using a few. I mounted the fuse panel behind the driver kick panel
60852
Discussion Starter #20
I swapped steering columns also from my 85 hatch. The notchback didn’t have a tilt column so i swapped it out with the tilt from my hatch.
wiring The harness to the stock cluster here.
60853
1 - 20 of 42 Posts
