1 - 20 of 27 Posts
I have the dash mount 8000, makes wiring so simple! The only issue I see is the red sswitch lights on the panel stay on as long as your battery is on.
I have one and like it a lot, except when you run low on battery it will just drop out the relays (shut off) when you crank it. ///J.T.///
Very badass piece IMO. We have them in a quite a few cars with out any trouble.
Especially on the 16v setting. If it gets low I have to hold the ignition button while cranking it.
X3 I love it, but when ur battery is low but still cranks it cuts off the switches (mainly ing) and is tough to start...
A VERY clean install though. would do it again.
ls1 s/s notch on 28s
I like that panel..didn't know i could use it to wire my car though..was looking into the k&r kit to wire my car but if i can use this im def going to save the 200$ an grab it
Do these operate good when you have on thick gloves ?
1 - 20 of 27 Posts
