1 - 11 of 11 Posts
from across the pond...
shit,that is a LOT of fuel.....i'm using 2 eliminator pumps with 2 x -8 Y'd into a -10 line that is Y'd at the other end into 2 x -8s to the rails...
bugger,i'm going to struggle to put 2 rails each side.....
no,on pump gas.don't forget it's 572ci and it'll want a lot of fuel. Yes,2 150# injectors per runner. On the calculations for injectors for 2000hp it said 230# of fuel per runner. Maybe it'll only need 1 set but i'm covering the angles...Also don't forget this is a street driver..
1 - 11 of 11 Posts
