1 - 20 of 45 Posts
Fixin to put a set of Ford motorsport 3.73's in. With the spray I'll be pushing about 1100 hp.
Think the motorsport gears will hold it??
Gas Passer
Chris Tuten has been over 200 mph with an 8.8; not sure which gears he uses but I am sure the FMS will hold up to 1100. James
Gas Passer
Looking to push a good bit more than that through mine as well. James
Bracket racer
Speaking of 8.8s....what kind of abuse can a set of stock 28 spline axles take? 5 lug Ranger rear end if it matters.
Medium Pimpin!
With a automatic ive seen them go high 9s with no transbrake, with a 5 speed and slicks, dumping it at 5k can break them. I dont reccomend trying it because when the wheel flys off it seriously screws up your 1/4.
Discussion Starter #11
I'm not worried about the housing, just the gear set.
Tellin' it like it is
We ran 5.20s in the 1/8th for years on that same gear in a 3200 pound drag radial car. We have FRPP 4.10s in it now running 4.90s and 5.0s.
Bracket racer
Good to know, thanks!
TRZ Rocks!
they live just fine, but brace the housing, housing flex is what breaks the gears
X2
8.8 in mine several 1.1X 60's at 3300 lbs. IMO the Motorsport and Factory Ford (used Explorer etc..) are the best quality and from my experience are more forgiving if the pinion depth/ back lash isn't dead on.
Bracket raced with a 5spd with 5k launches for 3yrs. Then went automatic and went 1.48 60ft with the same axles. Now lemme tell ya i think i was lucky but when i pulled em outthey were twisted like crazy.
X2
I have a couple buddies that are Ford Techs and they tell everyone to use Ford Motor Sports gears over anyone elses because of set up..
Also like mentioning it is bracing that is needed to keep the gears alive, but then you get to the point is if 50 pounds of bracing worth it.
Car ramrod
Automatic with no transbrake they can last. In a 5 speed car on slicks all it takes is one 5000 rpm launch to snap an axle
1 - 20 of 45 Posts
