1 - 4 of 4 Posts
Hey,
I need to replace the bearings in the 8.8 I have in my S-10. The ends have been changed over to the Moser 8.8 mustang ends so all the different brake combos works and axles go in and out like a 9 inch. Any way I was wondering if there is a Timkim cross over part number for Mosers 9507T Bearing O.D. 2.834" Bearing I.D.: 1.562".
John
I could be wrong but the small bearing is a stock part. so there should be a timken crossover if you know what the original ford number is.
Well Moser and Strange sells replacements. Ended up getting Mosers. When you go through there catalog they sell small bearing stock axle and small bearing after-market axle which has a bigger ID. Small bearing stock I can find all day long. Small bearing after-market I can only find through the rear companies.
1 - 4 of 4 Posts
