1 - 11 of 11 Posts
Is this still done? The NHRA book is a PITA to find info.
Thanks,and that only involves a cage inspection, not the chassis? I'm asking because I'm building a kit car, the chassis is built out of box tubing and it has an 1 5/8" cage. I'm hearing about the box tubing being a no go,but thought the chassis was not part of an 8.50 cert. My thought at first was that I could add a door bar and a window net, and be good,but not sure now.
Better call your tech inspector on that one. Might have been a good idea to post the pic first. lol. What's that going to be anyway?
Factory Five Daytona Coupe
Building for the street,and just looking to be able to make some track passes without too much hassle.
Isnitntoo late to replace the section of down and dash bar. A pillar can be in segments so the roof bars are useable as they sit.
Discussion Starter #7
After digging around the rulebook, I found that a cage can only be attached to a minimum of 1 5/8" round or 2x2" box tubing. The box tubing is unfortunately 1.5". Might be able to replace the pieces where the cage lands. Will talk to a local chassis guy and see if he has some ideas
Discussion Starter #10
Yes, can be square but not under 2x2". At least that's what I read.
I went out and measured... Mine are 2x2 and a large gusset under it to the frame.
1 - 11 of 11 Posts
