1 - 5 of 5 Posts
Has anyone mounted one of these in the trunk? It says to keep away from engine heat. No room under the dash either. Thanks
i dont see why not , but i would ask others opinions too , as long as the coil is under the hood shouldnt matter,
feck that would be a long coil lead
Dan
We ran a 7AL-2 and a 7AL-3 box in a 255" rear engine dragster for years. The ignition box is always in the front and we run two 10 ga wires to the back to the coil which is mounted as close as possible to the dizzy to keep the shortest coil wire. Just make sure you use the MSD extension wire for your crank trigger and keep it away from any electric motors like your water pump, fuel pump or alternator.
1 - 5 of 5 Posts
