1 - 3 of 3 Posts
New 7531 won't start. 10 gauge wires direct to battery.crank trigger and coil ran on dyno, will spark when tripped with jumper wire.fiber opitic syn hooked up.850 amp 12volt battery 13.2v before cranking 10.2v while cranking.Is this enough volts to holdthe switching wire in?Is there anything that needs to be set before starting.
Discussion Starter · #2 ·
Charged battery all day volts are .5 higher.When I unhook the crank trigger and fire the box with a jumper it will fire once then won't fire again, mess with it a little while it will fire again.I put a new shielded and grounded trigger cable on it, no difference. when cranking motor the red light on the box flashes randomly.Double checked my wiring.
Got mad, decided to take a break and have a cold drink.Calmed down, put a new crank trigger on it.Fired right up.Hell yeah!!!!
1 - 3 of 3 Posts
