1 - 4 of 4 Posts
I had a 71 Ventura that was mini tubbed before I bought it. It had 14" of space in rear wheelwell.
I have 325/50/15's mounted on a 10" rim.
Rear will be narrowed appropriately.
Do you get that much space with a DSE minitub?
Has anyone run that tire with a DSE mini tub?
I have a DSE mini tub on a 69 Nova which is pretty close to yours. DSE said no rim larger that 11". I run a 10" rim with a MT 315 drag radial. It's a tight fit but it does not rub at all. I pretty sure I could run a 325/50 and it would fit no problem.
I have 325/50/15 mounted on a 10" rim. Going to narrow the Moser 60 to fit with 3.5" BS. Thanks.
Did you re-box the frame? I was thinking if a 1/8 or 1/4" plate plug welded.
My chassis guy did all the work. He notched the unibody frame rail so the tire would fit. I believe the DSE kit comes with everything ya need to do that.
1 - 4 of 4 Posts
