1 - 2 of 2 Posts
We are using an Ultimate 8" UCC converter with about 775 ft lbs of torq. Lenny made it as tight as possible. The slip data looks good mathematically. 7400rpm trap/ 94.4" rollout/ 4.56 gear/ 141mph. The incrementals are 'off' IMO 1.39/[email protected]/[email protected] So as you see the back half is pretty strong for a NA motor. Yes we need to get the 60ft down in the low 1.30 range. Anyway I was wondering if he could be 'driving-thru' the converter in the first half and then at high rpm the converter locks up near 5%??? We have been told it may be necessary to upgrade into a larger diameter converter but that was BEFORE we had any run data. Thank you!
1 - 2 of 2 Posts
