1 - 5 of 5 Posts
I'm using 15x12 with a 6 b.s my frame is notched all the way. My rear is also narrowed two inches each side
yeah notched mine. 12 rim. can fit a 315 radial on it no problem. rear is narrowed as well
X2, I got. 5" bs with narrowed rear. My advise to you is if you notch the frame go as much as u can. I did it once and it was not enough so I had to notch it again.
ok thanks a lot and your all runing stock controll arms or ladder bar or four link and do you have any pics
1 - 5 of 5 Posts
