1 - 12 of 12 Posts
Here go`s........
Alum. heads / block
fiberglass / carbon fiber front end, doors, bumpers, deck lid
alum. radiator
fenderwell delete
rack & pinion
steering colum(sp??) surgery
crossmember notch
alum. driveshaft
heater delete
battery relocate
alum. tubing for exhaust
racing buckets / alum. seats
aftermarket brakes / steering arms
lexan window`s
Cut the frame off in front of upper a arms and plate the front, run a tube out to support, a fiberglass bumper and a tube radiator support, glass fenders and hood, spindle mount wheels and brakes. smaller radiator, move trans cooler to the back, dont use steel braded lines use the push lock, fiber glass inner fenders
TRZ is all I would use on the front A-Arms, Steering arms and rack kit.
I used Wilwood dyna lights, for brakes, saved over 125 lbs off the front between all of it. ( Malibu's have a very heavy spindle) I switched to a F-Body set-up
I saved 50# by going from stock front disc's to Wilwood's. Remenber, unsprung weight removal is most desireable. Core supports are heavy and can either be lightened, or you could fab a new lighter one. You can take 15# out of the firewall. I took 10# out of my stock steering column.
This is all on a '69 Lemans, but it's still an A-body. My car is 2990 without me in it. 12 point cage certed to 8.50. I'm hoping to reach 2850# after this winter.
Tubular A-arms - 30 - 35 lbs.
Strange or Wilwood Brakes - 45 -50 lbs.
Manual Rack kit w/ alum steering arms - 33 - 38 lbs.
are a few of the things I know for sure.
+ all the cutting / plating / fiberglass etc.
All that weight savings plus you get stuff that works better and is safer on a dragstrip.
It's just like a Scotchman and money. If you watch the pennys the dollars take care of them selfs. If you watch the ounces the pounds will come off.
Lord of Lords
Don't forget to cut out the side imact beams from the doors, they're a PITA to get out, but they're worth 11lbs each side if you plan on keeping the stock doors.
1 - 12 of 12 Posts
