1 - 2 of 2 Posts
DA afco fronts with BNC. Should I do coil overs or afco conventional springs, but the seem like they might be to short, or Santhuff's springs.
I was going to switch the rear to caltracs, but that will prob wait till later. Ladder bar set up with the stock leafs but ditching them for coil over set up in the rear.
I used the QA1 beehive springs in the correct weight. Kind of in between the "stock" coils or coil overs. With the coil over spring I didn't like the way the stock mount shocks had to hold all of the weight on the stud, besides it kept blowing the upper little bushings out and didn't have enough stored energy to work good.
1 - 2 of 2 Posts
