1 - 8 of 8 Posts
HI is only a 6mph gain from a 100 shot the normal ,it is a zex plate jetting is n/46/ f/43 ,i know all motors react diff to 100 shot , few more things to help car is sec gen camaro street strip car full weight around 3650-3750lbs id say ,motor zz454 edey recoval heads,9.6 comp comp hyd roller cam 230/[email protected] 50 110 lobe sepration, vic jnr ,2 inch headers twin 2 1/2 exhaust system,digi 6 th400 3.5k stall 3.42 gears 26 inch tall drag radial, tune looks good 6psi, ngk v power 8 plugs 93 pump gas pulling 4 degs from total off 39 total bottle pressure 900-950 ,got told dnt bother pulling any timming at all on 100 shot with such low copmression any thoughts on this be gud car gains 9 mph on 150 shot
regards
victtor
new zealand
At what point did you activate your system. If it was at the starting line compare your 60' time with spray compared to without. This might tell you something very important.
an "100hp" shot and 6mph is a good gain on a car id say. if you think about it you and your buddy are gaining roughly 3mph per 50hp, u gained 6mph at 100pill, put the 150 init and youd prob gain close to your buddies 9mph. i have a 3800lb streeter aswell, with a .73 pill (making an extra 225 whp) i picked up 11mph. put some mroe pill init. and like mentioned above when was it activated, and what difference in the 60ft ?
as far as 39 degrees goes, i used to have a zz502 which is the big brother, and i ran mine at 38, tried it at 42 and it made no difference. with a comp fairly low( and cylinderpressure too) he can run that much timing with that amoutn of nitrous it still shouldnt hurt itself.
What kind of converter is it? 3500 stall means nothing. 9 inch? 10 inch? 11 inch? Brand? Custom or off the shelf?
1 - 8 of 8 Posts
