1 - 11 of 11 Posts
I went from a 6al to a 7AL-3. I run the 7AL3 box in all my cars. Alot more options if your going to run a two step, or spraying the car.. GREAT BOX!!
Proud Canadian
Zero performance benefit ...been there done that..
Yup me too. Nothing. My wallet was lighter. I did it though chasing a stumble. 6 boxes can take a lot.
I went from a suspected malfunctioning 6AL to a digital 7 and saw a few hundreths in similar conditions. IMO, not worth the upgrade unless, as stated, something is wrong, or you want the extra features.
most people dont realize a plug only needs a certain amount of energy to fire it,any extra is just not used. there for you never run an ignition at max output,if you did then you would see a benifit when installing a larger output box.a good working 6AL will support about 1000 hp.
1 - 11 of 11 Posts
