1 - 2 of 2 Posts
will a ford 9 in rear end 50 inches from backing plate to backing plate fit with out having to mini tub if so what off set should i run on my wheels
My Strange spec shet says my factory replacement 9in is 55in housing end to end. 15X8 rim with 4.5 offset fits factory tub with a 275/60/15. Might want to put this in the stock suspension section.
1 - 2 of 2 Posts
