1 - 4 of 4 Posts
i just put a tko 600 tremec in my 69 camaro. I upgraded to 1350 ujoints on both ends now the question is.
What is the threshold when i know i need to go from the stock 3 inch dia driveshaft to a 3.5inch dia. drive shaft.
Car has bout 500 at the flywheel. 12 bolt with 3:73. drag radials cal tracs.
80% street 20% track.
Will a 3inch dia be fine?
Should i go up in size?
length between u joints is appx. 47"
thanks
a 3 inch shaft will be fine, but have everything made new dont use the original shaft.i have ran real fast with a 3 inch chromoly shaft,but didnt use drag radials.will it dead hook with a stick car?
there is a couple really sharp drive shaft guys on here... I am sure they will chime in.
47" on center can stick with 3" diam shaft at that power. Make sure whoever you use that you DO NOT GET a china slip yoke..
Spicer, AAM or Neapco.... anything else and they'll have issues of twisting if they don't break altogether...
1 - 4 of 4 Posts
