1 - 3 of 3 Posts
Is there a way to get rid of the vent windows on 67 camaro doors?? Has anyone done this or know of anyone that has done this without using fiberglass doors?? :(
I've done this two or three times. And the easiest way is too just get a set of 68 doors and hinges and modify the post to bolt the hinges on. Its actually very simple when you get into it. The only difference is the 67's have a cast hinge instead of the 68's stamped steel. The bolt pattern is different. Another way is to tack them in place and play with the gaps until your happy, then just weld the hinges to the post.
good luck.....
bob
1 - 3 of 3 Posts
