1 - 20 of 141 Posts
So........I bought a just restored 66 SS 396 Marina Blue Chevelle Factory A/C car.........It's a decent resto but not perfect by any means.......so....the plans are to do the Brake, Suspension, and wheel and tire thingy to get that Pro Touring look ......and the car will never see a cone course....so...it will be a driver and Power Tour car.........Now for the Interesting stuff..........It's gonna get a 2013 Camaro ZL1/LSA 6L90E drivetrain........The factory A/C will be replaced with a aftermarket system from vintage air and the stock interior will be retained..........I know I'm going to have to cut out the trans tunnel and raise it to fit the trans....the end goal is to keep the stock console and shifter for the stock appearance.........Here are some starting pic's of the car......
And here's the engine........It's only got 2100 miles on it
Stay tuned....
Ken
Cool project. Beat of luck
I received more parts today......since the new Camaros have Electric Power Steering, I ordered a Kwik Performance raised alternator bracket assy along with their Power Steering Pump integrated into the brackets.....I also ordered a complete wire harness kit from American Autowire......The existing fuse panel in the car is showing it's age and is pretty much toast.....So....we are going to rewire the whole car.....The A/C compressor is a slight problem as with the blower belt tensioner taking up the area that would allow the raising of it.....so .......I am going to have to keep it down low and make my own brackets...........The Fun continues.....
Getting ready to start...........
Discussion Starter #7
It was hard to take a wrench to the first bolt to take this car apart.......But........Got a little bite into it today and the ball is now rolling...........Hope to have the LSA in place by the end of next week......Pic's to follow as things happen
The Wilwood Brake system will be here early next week and a Ricks Vaporworx tank is also on the way.....
Ken
Discussion Starter #8
Just want to mention that the build will go very fast on here because the car is already finished ..............I just noticed this build section on the Bullet so I will be updating the links to the original build daily........or twice daily.......LOL
Ken
Discussion Starter #9
Got the old drivetrain out and we are getting close to starting with the "Fun" part of the rebuild........Gonna find out what fit's.....and what doesn't......Then make it fit.........Everything will be documented here so as to help others in the future.......or.....If anyone has been down this road, feel free to help with any advice.........My biggest concern right now is with the 6L90E trans.........I'm not concerned so much with cutting the tunnel.........But by how much will be sticking down below the crossmember as this thing is huge.......I also did some rough measuring and it seems like the top of the supercharger will be about an inch too high for the hood to close.......But....I'll know more when we get a little further along...
Ken
Discussion Starter #10
Got a little more done today............Time to clean and detail the frame and get the new suspension and Brakes installed....then get the engine installed.....
Ken
Discussion Starter #11
Started to open up the Ridetech boxes to get everything organized and ready for assembly............How did they know these boxes were coming to me.......LOL......Look closely.........Gotta love it!!!!
Ken
Discussion Starter #12
A couple of things happened today.........The original drivetrain is now gone and on it's way to be installed in another Chevelle and to live another day................And.....After looking at the 6L90E trans and measuring everything.....I'm just not comfortable that the trans pan will be high enough for me to drive the car comfortably worrying about that pan hitting something as the car will be a couple of inches lower than stock with the Ridetech Coil-over suspension.....So.......I'm going to buy a built 4l60 trans that will fit without the trans tunnel surgery and pan issues......I need to resolve some issues butJohn at Speartech has said there wouldn't be any communication issues with the computers .....so....looks like that's the way I'm going to go......(That's today's plan anyway.....LOL)
Got some more boxes today also..........Christmas in September..........Dakota Digital VHX Gauges........and a "Real" set of brakes.......
Ken
Discussion Starter #13
Made some progress today......First.........I ordered a built 4L70E trans to replace the 6L90E........John from Speartech is going to make the harness mod's to suit the different trans and said it's actually much easier now......... So.......I took the trans off the back of the engine and brought the engine home to meet the car for the first time......LOL.....The new trans will be delivered in a couple of weeks so while waiting I'll get the new suspension on the car......then continue with the engine install.......If anyone needs a 6L90E with 2000 miles , let me know...........Here are some pic's from today.....
Ken
Discussion Starter #14
LOL......I took the stock steering arms to the shop today for glass beading and painting......got that done and when I got home I installed the upper control arms and started to install the disc brakes and the steering arms.............As soon as I started to install the parts I knew I had a problem as the kit bolts wouldn't go thru the arms..........Hummmm......I read the instructions and ......LOL.......I don't have a drill big enough at home to drill the holes out to 1/2"..........So.....I had to stop for the day and finish then up at the shop tomorrow..........Dam Instructions......
Ken
Discussion Starter #15
Got a little more assembled.......Got the steering linkage installed and the brake caliper mounts.......I'll get the rotors and calipers installed then on to the rear......
Discussion Starter #17
Got the front spindle hubs installed......when I opened the box with the rotors I noticed they weren't cad plated.......So I sent them out for plating to keep that rust from showing up later.......I should have them back for installation tomorrow......I also ordered a Posi unit so I decided to wait for that to show up before getting involved in the rear end......so....I jumped into the inside and finished getting all the original A/C removed along with the dash and wiring......I also sent the stock AM radio out for conversion to AM/FM Satelite..............Started mounting the Vintage Air system.......Having Fun!!!
Discussion Starter #18
Lot's of balls up in the air.........waiting for the firewall insulation to show up........and the Rotors were picked up from the plater today.....so we got the front brakes installed......I also got a call from the transmission shop and the 4L70E trans will be delivered tomorrow............so after getting the brakes installed I decided to get the rear end out of the car and take it over to Jimmy Quinn at Chassis Service to get the posi unit installed and get the ring and pinion replaced if needed....seems to have a lot of backlash.......I should get all the Ridetech rear suspension parts in tomorrow and have the engine install going in a day or two........
Ken
Discussion Starter #19
A couple things showed up today......Posi unit and rear axle assy was taken to Chassis Service for rebuilding.........also my Level 6 4L70E trans and converter showed up also.........ordered new brake lines also..........Gonna be a busy weekend
Discussion Starter #20
Well......I guess I was Lucky that the car didn't have a posi unit in it when I bought it (if it did I probably wouldn't have taken it apart)
.......After getting a posi unit and dropping the rear end off at Chassis Service for installation........... .........I go over there today and I was shown what was going on in the assy...........In disassembly the shaft that has to be removed to get the axles out was marred and scored so bad it to be cut off with a cut off wheel to get it out......also the rear was filled with motor oil rather than heavy weight oil.......and both axles are shot in the bearing area..........so......New Ring and pinion, bearings , and axles are on their way........Darn$$$$$$$
But.....after getting home I got the rear coil-overs installed waiting to get the rear axle assy back next week........
Ken
1 - 20 of 141 Posts
