41 - 42 of 42 Posts
1.220 is very common.Alum rods is only thing you can match length too.Steel rods are set in length.You adjust deck ht or gasket.This is basic engine building 9th grade shop class.
I had a 603 with a 12 deg profiler head and single carb that made 1225hp. Like stated above you dont need 650ci to make that with the right heads and setup.
41 - 42 of 42 Posts
