1 - 16 of 16 Posts
Guys i have a 615 inch chevy,11to1 compression sonnys 14.5 degree heads 877/875 on the cam it was built for a f3 and alcohol,the heads flowed 571 intake and 390 on the exhaust @900 I am going to just run it on motor and 2 stages this year,my question is im not sure what carb to use this year,i heard the king demon 1295 was good,im not sure what kind of power this motor is making its never been dynoed,anyone ever run a combo simmular to this and if so what kind of power did it make and what carb did you use,I was told that motor should be making 1000 hp because of the heads,, but im not sure i may just have it put on the dyno,thats the motor in my pic...
i had a 615 11.5comp with edelbrock/musi heads 785 lift cam made 923hp on a engine dyno.not sure with those heads though.sounds like around 1000.
i would go with a pro system.they will probably sell you one of those somthing like 1500cfm deals or quick fuel has a 1300 also.never heard bg carbs make more power than the holley based carbs
Discussion Starter · #7 ·
YOU GUYS ALL ROCK,LETS JUST ALL HOPE IN 10 YEARS WE ARE NOT RUNNING ARE CARS ON ELECTRICITY!!!!!!!!!
Hello do you have a number for Dale ad Cfm and Braswell so i can call them and get a carb recomandision for my 632 motor.I calld pro system and i want a nother apinon.Tanks Arni in Iceland
Same cubic inches as mine only you have more cylinder head but less compression and cam, I would say it will go 1000, What did Patrick suggest ?? He put one of his 1600's on mine for 1100 hp. and it was 28hp better than a borrowed but new 1250 from another shop.
1 - 16 of 16 Posts
