1 - 2 of 2 Posts
Having problems with 396 bbc the #6 will not fire
hp 950 carb
air gap dual plane intake
hydraulic cam
motor has very few miles on it
6 al box, msd distributor, blaster coil
Have tried most everything I can think of looking for any suggestions would be appreciated
compression 150, checked for vacuum leak using carb cleaner, reset valves everything appears to be moving fine, cam looks fine, put different distributor in, pulled intake replaced gaskets, switched plug wires around, tried new plugs, plug is wet with gas when you pull out of head, when you ground plug outside of head it has good spark, has fresh gas
Is it possible for one cylinder to get flooded with gas
It's possible that the spark is jumping out somewhere before it fires the plug when under pressure. What does the inside of the dist cap look like? How far of a gap will the spark jump at the plug end of the wire. Compare to the one next door.
1 - 2 of 2 Posts
