Find a used turbo set-up off of a late model 6.5. You can get the whole shebang for a fraction of what a BANKS turbo kit will cost you. Your mileage will go down some by adding the turbo, but you can get a good deal more power out of it. If you stay reasonable with your expectations, the 6.2 will run for a long time.Get the 6.2 and buy a Banks turbo kit for it. They are pretty cheap
I didnt think the 6.5 setup was a direct bolt onFind a used turbo set-up off of a late model 6.5. You can get the whole shebang for a fraction of what a BANKS turbo kit will cost you. Your mileage will go down some by adding the turbo, but you can get a good deal more power out of it. If you stay reasonable with your expectations, the 6.2 will run for a long time.
Will a 6.2 diesel tow a 18 foot open car trailer with a mustang on very well? I really like the look.of the80s chevy duallies but if they are junk i dont want one
I knew there were some things that needed done, the good thing is that 6.5 and 6.2 stuff seems to be everywhere and cheap. I know a guy with a late 90s 4x4 dually crew cab 6.5 that has been sitting for probably 4 years with alittle over 100k miles. He told me i could have it for 2000 cash last year, its so damn big i dont know where i could park itIt " bolts " on but a few things need to be done for the square body style trucks . Oil feed for the turbo can be used from the OP switch port with a braided line . OE is a port directly below
the turbo , right front of engine . The main problem is the turbo has a clearance problem with the heater core housing . Some have used an S10 housing . 6.2 heads are also a little different as
far as the injector angle in the head . The 6.5 heads took care of that and this helps with the right side manifold .
6.2= No power! and they eat starters
Truck is ok tho
Really? The lamp is not tied to the glow plug relay? I'm going to have to look that up on my Ford service manual. Never too old to learn something new....The glow plugs on your PSD are likely still on, even after the lamp goes out.
And any 6.2 I've towed with has run STUPID hot towing. Not worth biting your nails wondering the whole time if you're going to make it.
If you like the look of the truck/body style, get one with a big block.
Buy the truck and do the cummins swap into the truck.Will a 6.2 diesel tow a 18 foot open car trailer with a mustang on very well? I really like the look.of the80s chevy duallies but if they are junk i dont want one
x2Buy the truck and do the cummins swap into the truck.
Nope. It's all in the calibration, but the glow plugs in most cases will stay on for 2 minutes from the key-on cycle, to eliminate any chance of smoke.Really? The lamp is not tied to the glow plug relay? I'm going to have to look that up on my Ford service manual. Never too old to learn something new....
