1 - 2 of 2 Posts
this trans came in 2 me blowing fluid out the vent pulled and installed new pump and convertor and still blowing fluid. the truck is used 2 taxi airplanes .it is a goverd truck it never gets over 45 mph.blows fluid even when its not pulling a load. in 2 miles it will blow out about 2qrts.
Check cooler flow... You should always replace the trans cooler when overhauling these units or add an air cooler to it and unhook the factory cooler......
Is the converter the correct stall ratio?
Pump is new Ford or a used / rebuilt part?
1 - 2 of 2 Posts
