1 - 4 of 4 Posts
What head, street motor shift at around 6400. cam is 738 lift 274 at 50. want to run dart 4500 intake and was thinking 345 as cast darts but they think 355. What do you guys think?
of course the dart 355 cnc is a way better power making head the as cast head probably doesnt even flow 400cfm and at 582ci will make a lot more hp with the cnc 355 head if the combo matches it.the only reason i can see not is if you dont want to spend the $.
btw i would run a super vic over the dart and why such a low rpm.
Super Vic and a set of Dart or AFR CNC 355 / 357's.. would be your best bet. Just money! I'd bump your cam up to a 775int. 748exh grind. A 582ci moves a lot of air, let it breath.
I ran this grind (Comp I believe) in my 496ci on a 108LC (3500lb car) years ago, using the Dart CNC 335 heads.. Had a nice bumpety idle, and worked great for street thumpin... went 10.20's foot brakin too on a 9" slick. ;)
Assuming pump gas... keep it atleast 10.5 to1, 11 to 1 range. Use a good MSD Ignition ...
You should make great power and still be able to run premium pump gas.
Lemme know if you need help with parts.
Have fun!
1 - 4 of 4 Posts
