1 - 10 of 10 Posts
engine is a 565 4.600x4.250 15 to1 comp gas ported 043 rings 3mm oil ,alum rods,dart 370 oval port heads fully ported with 2.350 titanium intake valves and 1.88 titanium exhaust valves with a 50 degree angle heads flow 440 in and 332 ex at 900 lift ,sniper intake fully ported,pro-system 1300 cfm dominator , shear plate,vac pump,2 1/4 to 2 3/8 stepped headers with 5 in collector mufflers. block has 55 mm roller cam bearings. car is 3300 lb 10 in tire car running a 180 gear powerglide 9 in 6000 converter and a 28x10 slick.gear is 4.11 need help with cam choice and rocker ratio mainly can run up to 950 lift dont mind tuning engine way up.also going to run q16 fuel.also would like some power estimate. sorry for the long post.
I'd guess you'll see 1025 to 1050 HP and I would be sort of worried with a 9 inch converter and good luck with hooking it up......LOL. My 565 only makes 960 HP and it has a 9.5 converter.
aka hulk
my 565 made 1040hp with bmf 350 heads steel rods and small roller.
sounds like my combo...but i'm lucky if i make 940,care to share the combo?;)
1 - 10 of 10 Posts
