1 - 20 of 62 Posts
I have a new set up but do to weather I can't make any hits yet so I'd like to get a idea of how fast I should go....
Set up is 565 with dart 360s, th400,3600 FTI converter,370gears,
Stock suspension on 29.5x10.5w weight is 3120lbs 2 foggers with 28s in both I also have a 7531 an 2 timers...the first on at WOT an hopefully the second in by 1.0....
7.90s- 8.30s maybe quicker??. .028 nitrous jets? 2-200 hits?.
We went 8.38 with 200 shot @ 3375# a few yrs ago. (big tire 4 link car.) your starting off pretty aggressively with that big tune for a new combo IMO. just sayin. good luck
Discussion Starter #9
It already had one kit on it before last year, I sprayed it with 36n 28f an went 8.42 blowning threw the convertor!!! Now the new items are 1 extra foggers,29.5w now instead of a stiff an a 15x12 rim instead of a 15x10 also car is about 170lbs lighter an a new FTI convertor
Those numbers in your Sig are pretty impressive!!! How big of a jet did u have in the fogger an how much HP N/A? I made 950hp N/A
1044hp on motor and a 32/40 single fogger tuneup.big tire car so it pretty much takes the full hit right out of the hole .most of the time anyway lol
yes i saw that.just with the small tire your not gonna be ableto come out on both kits (500hp) and a lot of et is in the 60..if you can get the 2nd kit on in .5 and the coveter/gearing ect is on the money like i said 7.90s maybe quicker. nitous isnt like a turbo car its hard to make up time later in the pass.i put a couple degrees of launch retard in and kills the whole run bigtime. over .1
Discussion Starter #14
7.90s would be great!!!! I tried the 40n 32f an the car went 1.22 60 but was to much for the car rite off the line an I couldn't never get down the track an that was on 29.5x10.5s an a 10inch Rims so hopefully with a wider tire an rim an 2 stages I'll see soom results!!!
Discussion Starter #15
I don't think even wit the 29.5x10.5w an wider rim I'll be able to get the 2nd in by .5 but who knows!!!!! .8 or 1.0 is what I'm thinking....we will see I think I will make a trip in the next month somewhere warm to find out
I'm on big tires like "another69camaro" and I agree that you can probably run 7.90's in the qtr when you get it lined out. Good luck. :p
Discussion Starter #17
Thanks for the input on this guys!!!!! Now I won't be able to sleep til I get this thing to the track...I see fofo said the track in Louisiana
NO Problems is a pretty tight track an the weather is in the 60s I think I will head that way real soon...
5.80 on motor at 3100 lbs and 5.10 on a 32 jet at 3230 on a drag radial
Discussion Starter #19
5.10 on one kit is is moving.....so this means if all go's well 5.00 for me shouldn't be a problem!! Dam I can't wait
1 - 20 of 62 Posts
