1 - 5 of 5 Posts
I have a 15-1 540 BBC conventional head what kind of ring gaps should I be at for a 400-500 shot?
Thanks in advance
Discussion Starter #2
Wiseco q16 piston that's probably valuable info..
Your probable going to get several conflicting answers for this, but I would go with .036" top and .042" second. That's based on the formula I use along with several identical combos, even using that same piston you have.
Thanks for the response that's close to what I was guessing.
1 - 5 of 5 Posts
