181 - 193 of 193 Posts
I'm sure that Jim checked it on the 521 build, and when I get my block back to my little shop I'll make sure that the lifters are not clanking around any. And if you have the need to bush the lifter bore you might want to think about going to a larger dia. lifter so you can run a more agreesive cam lobe profile and have a larger wheel and axle.
My little build is and will be one on the cheap and with good parts on hand.
Depending on what block and what lifters you may actually have to run a hone in the lifter bore.
Stan
  • Like
Reactions: BBF612
You could be surprised if you are using new lifters. Sometimes they come in a little over.
Stan
Discussion Starter #189
Roughed it into pipemax to match the dyno numbers more or less. To make close to 800 hp with this engine you would need more compression and a cam that would peak close to 6500 to 6800 rpm.
520.689 Cubic Inches @ 6000 RPM with 106.00 % Volumetric Efficiency PerCent and 10.5 CR
Required Intake Flow between 310.1 CFM and 328.5 CFM at 28 Inches
Required Exhaust Flow between 201.0 CFM and 230.6 CFM at 28 Inches
600 RPM/Sec Dyno Test Lowest Low Average Best
Peak HorsePower 647.7 674.3 687.6 701.0
Peak Torque Lbs-Ft 628.5 654.4 667.3 680.2
HorsePower per CID 1.244 1.295 1.321 1.346
Torque per Cubic Inch 1.207 1.257 1.282 1.306
BMEP in psi 182.0 189.5 193.3 197.0
Carb CFM at 1.5 in Hg. 958 1066 1120 1174
And with 13 to 1 CR peaking at 6500 rpm.
520.689 Cubic Inches @ 6500 RPM with 106.00 % Volumetric Efficiency PerCent
Required Intake Flow between 336.0 CFM and 356.1 CFM at 28 Inches
Required Exhaust Flow between 217.8 CFM and 249.8 CFM at 28 Inches
Peak HorsePower 742.3 772.9 788.1 803.4
Peak Torque Lbs-Ft 665.0 692.3 706.0 719.7
HorsePower per CID 1.426 1.484 1.514 1.543
Torque per Cubic Inch 1.277 1.330 1.356 1.382
BMEP in psi 192.6 200.5 204.5 208.4
Carb CFM at 1.5 in Hg. 1038 1155 1213 1272
And to use all the head flow at 14 to 1 and peaking at 7200 rpm to make close to 900 hp.
520.689 Cubic Inches @ 7200 RPM with 106.00 % Volumetric Efficiency PerCent
Required Intake Flow between 372.2 CFM and 394.9 CFM at 28 Inches
Required Exhaust Flow between 241.2 CFM and 276.7 CFM at 28 Inches
Peak HorsePower 839.8 874.3 891.6 908.9
Peak Torque Lbs-Ft 677.5 705.4 719.3 733.2
HorsePower per CID 1.613 1.679 1.712 1.746
Torque per Cubic Inch 1.301 1.355 1.381 1.408
BMEP in psi 196.2 204.3 208.3 212.4
Carb CFM at 1.5 in Hg. 1150 1279 1344 1409
ok i firgured with those heads the dominator intake and shear plate it would have a few more rpm . and there probably is next round .
