i have two set's of chevy heads ,i'm needing some help to figure out what pair to run on my 505. the car is 3,500 pounds without driver , 10.5 tire ,stock suspension.
505 is 13.5:1 solid roller i can buy the right size cam to make heads work, 7,000 rpm shift point ,victor intake,1050 dominator,150 -200 hp shot big shot plate. turbo 400 ,4.10 gears
mild ported #990 rec.port open chamber heads with 1.880 and 2.250 valves
mild ported#781 same as #049 oval port open chamber heads with 1.880 and 2.19 valves
it is a 1/4 mile street car that runs mid 10's with a 8.5:1 454 and oval port heads ,plus a 180 shot going through the traps at 6,500 rpm
thanks
thanks
