I finally got my rpm recorder working. Found I am only dropping 500rpm between 1-2 and 2-3 shifts on my t-400. I shift at 6400 and it drops to 5900. Converter slip works out to 12%. Cross the line at 6600.
Is this good enough? Or am I leaving some on the table? Is it worth sending converter back to tighten it up 500rpms? Anything else in the trans would cause this?
Converter is an ATI MRT 8". It was made for the car when I was at 10.90. I am now at 10.00/133 with taller tires. It 60's great off the t-brake, 1.36 60's leaving at 2800. Don't really want to give that up. Foot braking can only get 1.41.
I did limit the converter feed a few years ago when I was having thrust issues. Went down to .157. Would that lossen a converter?
