1 - 20 of 23 Posts
Senior with common sense
Discussion Starter #2
Is it just me?, that engine looks like it's never been installed? :confused:
If you look at what appears to be ground cable you can see that it has a ring on it from a bolt being tightened against it. So that would lead one to believe it was installed, unless that ground is used during factory fire up.
Satans Daddy
You could put that in a 2019 Camaro and go 2 seconds quicker ;)
No doubt, looks to be a flood recovery, the coil packs were pulled and the bolts are missing.
No doubt, looks to be a flood recovery, the coil packs were pulled and the bolts are missing.[/QUOTE]
There are enough spotless corrosion free "virgin" machined metal points, the bare alum. and those paper labels that tell me it didn't go in water to all those low points.
Banned
Or you can just buy a "hellcrate" for the same price and not worry about what the history of it is
Maybe on the top row of a transporter truck,
that might have took the short cut thru that one LOW Bridge at 11foot, 8 inches or so.
The one posted here not long ago, with the video of the dumbshit tearing his roof off of his van / trailer.
1 - 20 of 23 Posts
