1 - 19 of 19 Posts
· Registered
its a pain in the ass, but can be done. probably going to have to cheat cut a bend a little bit, or even pie cut it.
do not use aluminum for a tight bend off the turbo like that.
· Registered
Buy a 5" doughnut from chassis shop , they are exstremely tight & will get what you need done
· Registered
That looks like you have 5-6" at most, the tightest 5" bend I have seen is on a 5" radius but that makes it 7.5" or so to the back of the bend. You will have to cut it and make it work and like Joe said, no aluminum there. I don't think even .120 wall will live.
· Registered
Turn the turbo if you can. Even a few degrees will help greatly.
If you can't turn the turbo get a 5"dia 5"CLR stainless tube and miter/pie cut it like the above pic "63vette" posted. They're usually available in 90deg bends and I have them if you need. Aluminum won't live there very long with high exhaust temps.
· Registered
Discussion Starter · #9 ·
Yeah your spot on it is a bit over 5" now but the engine is going back another 1.5".
Thanks for all the idea's guys.:)
· Registered
oops i miss read what you said. you said 5" on 5" center line, i just assumed it was a doughnut!
i had to make one of those "style" downpipes on friday in 3". its a pain. take forever to weld too, i always allow the metal to cool before i move to the next spot.
· Registered
1 - 19 of 19 Posts
