1 - 20 of 35 Posts
Andreas....Are you able to share your camshaft specs? I understand if you do not want to.
Engine sounds very responsive.
Discussion Starter #14
It´s Disomma camshaft. If you want that, need to call Anthony Disomma.
Discussion Starter #15
I like the chop of the cam . Sounds bigger than 427 cubes.
It´s 11.0:1 compression ratio. Maybe that´s why it´s sounds like that.
Im still running with 4" stroke to hold piston speed lower.
With big stroke like 4.25" and 10 000rpm it´s not safe anymore.
Andres
51mph+ gain in the back half! Amazing build and putting it down the track! I'd say this will make the end of your 2019 racing season a memorable one for sure.
The run shown wasn't exactly perfect on the first 60' either. Pretty considerable bounce. And it shows on the short time compared to the 1/8th and 1/4 times. Did the driveshaft data show much spin? That thing gets it!
And I agree it sounds awesome at idle.
1 - 20 of 35 Posts
