1 - 7 of 7 Posts
winners circle
I got a set of 5/8 wheel studs for my axles but i can't find no instructions on how to install them correctly.How tight are they in the axle? Do you use locite when you put them in the axle ? Thanks for any help
You put the studs in the axel and tighten them to 120 ft lbs I think. No sealer, then you torque the lock nut to 100 ft lbs.
Mine are not threaded into the axle. They have a small shoulder and the axle has a clearance hole for the stud,and there are lock nuts on the back of the axle flange....you know those nuts that look crimped on the end...don't know how else to explain it.
I just did mine last night, Strange axles and 5/8 studs. Instructions said to use red loctite on threads and torque studs to 95 ft-lb in axle, then torque jamb nuts on back side to 70ft-lb.
Craig
winners circle
Craig
Thanks now i can get those put together.
1 - 7 of 7 Posts
