Status
Not open for further replies.
1 - 13 of 13 Posts
Ultra-Carbon 4×8 flat sheets are created to exceed the industry standard for flat sheet quality. With a mirror-like clear gel coat finish, you won’t find a nicer looking flat panel sheet material from any supplier, regardless of price. And speaking of price, our 0.035″ and 0.045″ flat sheets in pure carbon fiber are virtually the same price as our competition’s carbon/fiberglass sheets!!
We offer four different variations of sheets for sale online, but we can make virtually any thickness tailored to your needs if you just call us with your specs at 253-906-8126.
Our 0.045-inch sheets are the standard thickness that most chassis shops will use for things like door panels, floor panels, and trunk filler panels. These panels are flexible enough to fit contours, but are also rigid enough to make into door panels. Can be bent into about a 15″ circle without fear of cracking or breaking. A full sheet will weigh right around 10 pounds.
Our 0.035-inch sheets are a super-thin, ultra flexible sheet used for making tighter bends like transmission tunnels and such. These panels can be bent into as small as a 10-inch circle without fear of breaking or cracking. A full sheet will weigh about 8 pounds.
Our 0.060-inch sheets are a slightly thicker version of our standard thickness panels where rigidity is more important than flexibility and light weight. A full sheet will weigh about 13 pounds.
Our 0.180-inch sheets are a 3mm core reinforced sheet used for making rigid panels like wings, bed covers, and floors that will see weight placed on them. These sheets are not flexible and will not bend. Due to the white color of the core material, end cuts of this material will expose a white edge. That white edge is easy to color with dye, paint, or a sharpie. A full sheet will weigh about 25 pounds. Call us if you have special needs for your core reinforced material.
Ultra-Carbon flat sheets do not come with an NHRA or SFI certification, but they ARE made with the same type of fire-resistant resin the certified sheets use. Our 0.035″ and 0.045″ sheets ship via UPS, four in a box, rolled up. Our 0.060 and 0.180″ core reinforced sheets ship via truck freight.
Discussion Starter #2
Flat sheets can be ordered online through PayPal on our website at www.ultra-carbon.com, or by calling 253-906-8126.
Prices start at just $500 per sheet for real carbon fiber sheets, no fiberglass filler.
Thanks you Greg for the .060 sheet looks great I have not had the chance to make anything with it yet but feels rigid enough for what I need and absolutely looks awesome, and great price
You're very welcome!!! I'm glad I could guide you toward what would work for your needs!!
Mine came a couple of days ago . I was shocked to see it rolled up , I didn't know you could do that . It looks awesome as far as finish . Greg , will it hurt it to stay rolled up ? My car is at the chassis shop .
No, it shouldn't hurt anything for it to stay rolled up. It'll still spring open a year from now and if it doesn't lay completely flat when you open the roll up, just leave it overnight and it should be flat by morning.
That would be bad as hell for a custom bed cover for my drag truck, just have to figure out the easiest way to cut for the down bars into the bed....? Would fit perfect i belive though as my truck is a long wheelbase 71 chevy c10, murder black paint of course hence my avatar name lol.
Discussion Starter #9
Here's how I worked around four down bars coming in at different angles and in different places....
Can you PM me on a price for a 14 inch x 18 inch piece for a wiring board if you sell pieces this size? Can be a blemish, doesn't really matter as it's going to be covered up and 1/2 under the dash, thickness enough to support holding a grid and controller, and a bunch of other stuff on it as well, will be mounted in a small round bar frame.
Discussion Starter #12
PM Sent.
That is awesome
Thanks!
Holy smokes, what craftsmanship.....looks great! I will be in contact soon thanks.
1 - 13 of 13 Posts
Status
