1 - 20 of 29 Posts
I've got a nasty vibration from 85 on up , I have the ES mount . Think I'm going to have to go back stock . What do you guys use ?
Ow my car is a 95 LT1 car
The mount looks way to tall
I have had a vibration before with those too. I used a piece of tire tube and put it between the mount and trans tail and the vibe went away. It will especially do it if it's brand new.
Its auto
I used the es for an older model on my 94. I made spacers to lower the crossmember since it was taller than the oe mount.
Discussion Starter #9
I've heard of guys shimming it 3/8 in to get rid of the vibration. Theres from what Ive read have been at lower speeds than mine .
what driveshaft and pinion angle?
^^ This. My LT1 car had the stock steel driveshaft in it when I got it and it vibrated. Switched it out for a stock aluminum one from an LS1 car and all was good.
Discussion Starter #16
Mine is stock steel . Maybe I'll try having it balanced
Under Construction
I had the same ES mount on my car, installed it just like it was supp. to be and no issues with it. I also had Prothane motor mounts and also had no issues with vibrations at all, might want to look into other options like warped rotors, rims/wheels out of balance, driveshaft/U-joint issues, ect. :smt102
Discussion Starter #18
It feels alot like a bad u joint , but I checked them and they seem fine , guess ill pull it back out and check it again . It does it under hard exceleration and above 85 . Its not the rotors . It is right there at the back of the tranny
angry russian
My prothane vibrated like crazy.. I did use 3m windoweld to fill in a stock mount and it lasted for a while with much less vibration- this is in a 99 formula
Discussion Starter #20
Ok so now I'm nervous ! I laid into it a little thismorning and when I let out I felt and heard a pop in the drive line , kind of like the gears binding . Guess I have to pull the shaft out again and recheck everything . Kind of worried its going to be missing teeth on the ring gear
1 - 20 of 29 Posts
